Re: Fast Hitch on M???
Posted by Wardner on October 10, 2009 at 22:10:11 from (4.154.243.124):
In Reply to: Re: Fast Hitch on M??? posted by soybeanjoe on October 10, 2009 at 18:56:08:
For an easy bolt up, get the hitch with two rock shaft arms. That would be 450 and 560. I don't know the serial number transition point between the 400 and 450 type hitches. There may not even be one if the early hitch became obsolete when the 450 came out.
The 400 has only one rockshaft arm. That hitch will fit the SMTA but the forward mounting point for the rockshaft bolts to top of rear frame lid.
I have two SMTAs with 400 fast hitches. I made an adaptor for the rockshaft anchor on one. The other has a 400 rear frame lid. Most people prefer the early fast hitch.
