Re: 706 farmall starving for gas
Posted by The tractor vet on October 11, 2009 at 08:30:47 from (75.19.126.148):
In Reply to: 706 farmall starving for gas posted by jasonjaberdeen on October 11, 2009 at 00:23:24:
First off Pull the sediment bowl out and make sure that there is no junk in the inlet and that you have full flow to the carb . Next Make sure that your timing is correct for the engine as i do not know what you have as if it is a C263 or a C291 or a C263 to a 291 update . THEN MAKE SURE THAT YOUR RUNNING 93 octane gas in it as that is the MINIUM OCTANE rating for that tractor . NO IF ANS OR BUTS about it I have worked on many 706 gassers and we still run them everyday on the farm . When ya set one up run the wright fuel in it she will do everything you ask of her .As for the shutoff solenoid on the carb they either work or they don't It will either start and run or it will not run .
