Posted by ScottyHOMEy on October 11, 2009 at 10:30:32 from (71.241.207.111):
In Reply to: leak on A posted by 7lazy77 on October 11, 2009 at 10:16:09:
Two possibilities.
It could be leaking down from the fan pulley above. They are oil-lubricated and notoriously leaky, especially if overfilled. There's really nothing to repair up there. If that's the source and it's more than you want to put up with, the only solution is to replace it with one of a similar design or one of the newer ones that runs on sealed bearings.
It could also, and just as likely if not more so, be oil on the crankshaft getting past the seal in the timing cover where the shaft comes out to the pulley. Thr solution for that is more complex The seal in question mounts in the back of the timing cover, and replacement involves splitting the tractor so the pulley and timing cover behind it can be removed.
Today's Featured Article - Timing Your Magneto Ignition Tractor - by Chris Pratt. If you have done major engine work or restored your tractor, chances are you removed the magneto and spark plug wires and eventually reached the point where you had to put it all back together and make it run. On our first cosmetic restoration, not having a manual, we carefully marked the wires, taped the magneto in the position it came off, and were careful not to turn the engine over while we had these components off. We thought we could get by with this since the engine ran perfectly and would not need any internal work. After the cleanup and painting was done, we began reassembly and finally came to t
... [Read Article]
Latest Ad:
[More Ads]
