Posted by IH fan on October 11, 2009 at 15:59:15 from (70.250.254.254):
In Reply to: Adding STP to gear oil posted by farmallhfan on October 11, 2009 at 09:07:01:
Should reduce friction as long as it doesn't get hot... and since friction causes heat, it should not get as hot. I wouldn't count on it curing anything that is already wrong with the transmission gears, bearings or seals.
That said, it should also not be necessary to add STP or anything else as long as the internals are in good shape and the correct lube is used.
This post was edited by IH fan at 16:01:13 10/11/09.
Today's Featured Article - The Ferguson System Principal An implement cutting through the soil at a certain depth say eight inches requires a certain force or draft to pull it. Obviously that draft will increase if the implement runs deeper than eight inches, and decrease if it runs shallower. Why not use that draft fact to control the depth of work automatically? The draft forces are
... [Read Article]
Latest Ad:
[More Ads]
