Re: H with mw overdrive, needs new cable
Posted by kfox on October 12, 2009 at 06:29:53 from (70.194.192.255):
In Reply to: Re: H with mw overdrive, needs new cable posted by glennster on October 12, 2009 at 05:54:17:
You might be able to replace the cable through the belt pully opening. Drain the tranny because the cable connects in the very bottom. The cable enters the tranny through a dowell pin on the side of the housing. The dowell pin is drilled and has a jam nut with a o-ring around the cable.The above post is correct about needing a heavier cable than a regular choke cable. kfox
