The A terminal on the VR needs to be hooked to the Armature (big) terminal on the gen. The unmarked terminal should go to the load side of the amp meter. The L terminal should go to the light switch (power in for lights) If it has the original 4 position charge control switch for the lights, LHDB it will not need the field wire hooked up to the grounding terminal of the switch. that wire is not used. If it has a battery ignition (coil) the ignition switch should get its power from the load side of the amp meter. If it is a mag ignition, it will not need any connection to the charging system, it is a ground to stop kill switch that is grounded when in through the switch body, and open when ON. The regulator may be toast, but may be OK from being hooked up wrong. Best of luck. JimN
Today's Featured Article - Antique Tractor Wiring Basics - by Curtis von Fange. One of the most neglected parts of old tractors is the wiring. After sitting in the elements for half a century or more much equipment wiring has deteriorated to sparsely covered strands of copper or other metal. Plastic insulation has cracked, mice have eaten through the older clothed style coverings and the exposed wires have reacted to winter moisture and salts by turning blue and powdery. Terminal ends have corroded, rusted or just plain evaporated away. Aged wires not only keep an engin
... [Read Article]
Latest Ad:
1953 Ford Jubilee Tractor. Last driven 5 yrs ago. Parked ever since. As is as seen
[More Ads]
