What wheels might I have?
Posted by G. L. Perry on October 12, 2009 at 12:18:59 from (69.245.138.156):
Bought some old 36" wheel/tires. The wheels may be 8", not sure yet. 2 pc with outer ring that comes off like old truck wheels. Has 8 cast mounts around outere edge to bolt to a center. PO is thinking some sort of Farmall wheel. I've looked at some pictures here of M's and H's, but can't see wheel clearly. BUT, looks like some have only 6 outer mount lugs. I don't have pictures yet, hope to get some. Sound like Farmall wheels? The tires say 12-36 and also 10-36 which store says is rim size suggested. They don't measure that wide to me. 8" is what I think. I'm finding the tires are too bad to use as I had hoped. Trying to recover purchase price thru rim sale IF I can even find what they are. They have some red paint on some areas.
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
