Re: SA not charging, again, would like to fix, once and f...
Posted by Janicholson on October 12, 2009 at 15:09:12 from (64.61.211.214):
In Reply to: Re: SA not charging, again, would like to fix, once and f... posted by scott#2 on October 12, 2009 at 12:16:45:
The relay contacts in the VR that control charge voltage literally ground the field terminal of the gen. If it is off of the tractor, it should read 0 ohms from the F terminal to the chassis of the VR where it is grounded to the tractor. This is the high charge position and can be checked on a new VR at the parts store. When the contacts are open on the relay with the smaller contacts, using a slip of paper between them to make sure they are apart, the F terminal to chassis of VR should be between 2 and 4 ohms. This is the low charge condition. The regulator chatters between full charge rate and minimum, to regulate the voltage to 7.2 volts on average. This is a very noisy 7.2 volts as it is the average volts of the chattering points that keep it under control. A crude method, but the only way in those days.
19 ohms is not in the ball park. JimN
Today's Featured Article - Show Coverage: Fair Weather Tractor - by Dave M.. No, Fair Weather isn't some rare brand. It's the kind you can't leave out in the rain. Here's how it happened. I had been casually looking for a tractor for weeks. I saw a few 9N's, but they had even fewer amenities than the 8N my Grandpa bought new in '52 with a Dearborn loader. That was 10 years before I was born, so I grew up thinking that 8N was the world's best tractor. Grandpa had greenhouses, with over half an acre under glass, and that 8N did almost everything. It was the only ... [Read Article]
