Re: 706 have to pump brakes
Posted by The tractor vet on October 12, 2009 at 19:31:28 from (75.19.126.148):
In Reply to: 706 have to pump brakes posted by Rtkman706 on October 12, 2009 at 08:29:12:
Well with out getting into checking pressures nd flow of the MCv pump we are al guessing . As for the brakes myself for all it takes to pop them off and tke a look at the disc's and springs along with the adjusters Here again we are guessing . It may well need a new pump on the MCV along with a rebuild of the MCV . And if you are not up on doing this then let someone that really knows how to check pressure and flow as this takes a flow rater and some special fittings to do the test.
