Clutch on Farmall M
Posted by tennhillbilly on October 13, 2009 at 06:18:31 from (75.136.207.35):
I have a 1943 Farmall M.My problem is disengaging the clutch without grinding the gears.I have a rebuilt clutch,resurfaced pressure plate,new throw out bearings,and any thing else that we thought was wore enough to make the difference,with no luck.You can crank the tractor with clutch disengaged and change any gear without grinding the gears but if you put it in neutral at any time and engage the clutch and then disengage the clutch again,you can 't get it back in gear without grinding.With the engine off and the clutch disengaged,I can reach underneath the tractor and turn the shaft by hand.Any help would be appreciated!
