Re: Charlyn Power Steering Mount
Posted by glennster on October 13, 2009 at 12:22:28 from (99.139.125.51):
In Reply to: Charlyn Power Steering Mount posted by james Ashcraft on October 13, 2009 at 11:02:55:
is the front of the torque generator hitting the bottom of the hood?? you may need to add one or two flat washers either at the torque genny to bracket mount , or to the bracket that holds the gauges to the post.it will tip the front of the torque generator down in the front, also, regarding the mount for the generator, the bracket that bolts to the block needs to be flipped over, and holes redrilled to get t5he belt to line up.
