D Slater said: ...If you want to be picky the cast # would end with DB on a 44 and the date code is wrong. Can't tell in the picture for sure, but if the manifold is on the original head the mounting studs should be 3/8 diameter. If so you may have to enlarge the holes in the manifold to fit your heads manifold mounting studs.
The casting code is the one under the part number, correct? So it's 12-6-I
As far as the studs, if I have a low compression head, as I suspect I do, the studs should be fine? The studs currently on my H seem to be different lengths. So I was going to get a new "Manifold mounting kit", along with the new gaskets.
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
