Re: grinding in differential on H
Posted by ChadS on October 13, 2009 at 13:47:44 from (4.225.94.30):
In Reply to: grinding in differential on H posted by Steve_x on October 12, 2009 at 22:05:38:
Might have sheered the housing where the bearings sit on the ends of the differential. The pinion shafts will hold it all together, the broken part stays with the bearing, but will rotate and eventually grind itself out and really do damage. Pull starting, locking up the brakes at high speeds will snap em right off! ChadS
