Re: IH 706 d
Posted by Owen Aaland on October 13, 2009 at 16:38:34 from (65.165.246.121):
In Reply to: IH 706 d posted by ih54 300 on October 13, 2009 at 12:24:52:
The early 706D came with an American made engine with 282 CID. It uses glow plugs to aid in starting. The later ones came with a German made engine with 310 CID. It is a direct injection engine and uses the shut off cable to also put the pump in the excess fuel position to aid in starting. If you are not familiar with the engines the easiest way to tell them apart is the D282 uses glow plugs so there will be a switch and glow plug meter under the steering wheel.
