Re: Talking about the 44 and the H
Posted by Pete in Holland, MI on October 14, 2009 at 10:05:37 from (198.36.94.33):
In Reply to: Talking about the 44 and the H posted by David G on October 13, 2009 at 18:52:15:
If the tractor is holding decent oil pressure, not using any oil to speak of, and is doing what you need it to, then there is no real good reason for to spend the money to rebuild it.
Once it starts to lose oil pressure, or keep gumming up plugs from burning of oil, or can perform the duties it used to do or should do, THEN look at tearing into it. Putting a few quarts of oil into it thru the season is much cheaper than an engine rebuild.
Does one rebuild their car engine, just because?
My 3 cents (adjusted for inflation)
Pete
