Re: Farmall M - Radiator Removal
Posted by glennster on October 14, 2009 at 11:46:42 from (99.139.125.51):
In Reply to: Farmall M - Radiator Removal posted by Melvin Ware on October 14, 2009 at 11:27:25:
couple other things, the radiator shroud needs to be loose and set back toward the fan to get the radiator out. the rad will not come out with the shroud on. there are 2 rubber mounting pads the rad sits on, so check them to see if they are still good. also, when the rad is off, check all the cooling hoses to see if they are dry rotted. if so, now is the time to change em. there is a short hose that goes from the top of the water pump to the thermostat housing, check that one too. if its bad, the thermostat housing needs to come off to get the new hose on, you will need a gasket for that.
Today's Featured Article - When Push Comes to Shove - by Dave Patterson. When I was a “kid” (still am to a deree) about two I guess, my parents couldn’t find me one day. They were horrified (we lived by the railroad), my mother thought the worst: "He’s been run over by a train, he’s gone forever!" Where did they find me? Perched up on the seat of the tractor. I’d probably plowed about 3000 acres (in my head anyway) by the time they found me. This is where my love for tractors started and has only gotten worse in my tender 50 yrs on this “green planet”. I’m par ... [Read Article]
