Re: hydro oil m farmall ?
Posted by CNKS on October 14, 2009 at 17:29:03 from (216.144.104.128):
In Reply to: hydro oil m farmall ? posted by crystalallis on October 14, 2009 at 14:58:37:
The pump really doesn't care. In that old system, 30W is fine. If you are sharing implements with a more modern tractor, use what the other tractor uses to avoid mixing fluid. If it was mine, I would use 30W non-detergent, as Hytran, being thinner may (or may not) leak.
Today's Featured Article - Experimental Tractors Article - by Danny Bowes (Dsl). Tractor technology appears to have nearly hit it's pinnacle of development. If you agreed with the subtitle, you are rather mistaken. Quite, actually. As a matter of fact, some of the technology experimented with over 40 years ago makes today's tractor technology seem absolutely stale by comparison. Experimentation, from the most complex assembly to the most simple and mundane component, is as an integral a part of any farm tractor's development ... [Read Article]
