You may as well unbolt the input shaft bearing cage and pull it out the front of transmission. Then you can check it out including piliot bearing. Will make it better to remove the bearing from input shaft and see if the bearing cage is bad and also check the rear bearing on input shaft. If the bearing just spins in the cage but is not loose enough to have play, when the bearing retainer with seal is bolted on it may keep the bearing from spinning.
Today's Featured Article - Oil Bath Air Filters - by Chris Pratt. Some of us grew up thinking that an air filter was a paper thing that allowed air to pass while trapping dirt particles of a particles of a certain size. What a surprise to open up your first old tractor's air filter case and find a can that appears to be filled with the scrap metal swept from around a machine shop metal lathe. To top that off, you have a cup with oil in it ("why would you want to lubricate your carburetor?"). On closer examination (and some reading in a AC D-14 service manual), I found out that this is a pretty ingenious method of cleaning the air in the tractor's intake tract.
... [Read Article]
Latest Ad:
[More Ads]
