Re: starter help
Posted by gbs on October 14, 2009 at 19:34:18 from (209.177.239.222):
In Reply to: starter help posted by stingray64 on October 13, 2009 at 18:39:49:
don,t weary about your tractor being changed to 12 volts ,best thing that could be done to assure reliable starting as long as charging circuit is wired right,6 volt starters will work, and 6 volt ignition coils also if used with proper ballast resistor, only good thing about 6 volt system was it kept you from using a hand crank part of the time
