Re: Mounting the rear PTO Pump for a Farmhand F11
Posted by Wardner on October 14, 2009 at 22:36:08 from (4.154.245.159):
In Reply to: Mounting the rear PTO Pump for a Farmhand F11 posted by cfitch on October 14, 2009 at 20:56:48:
I don't know Farmhand from Farmall but I assume you are talking about a Prince pump. On the side of the pump body you will two tapped holes. Secure a heavy piece of flatbar (3/4" x 2') about 15"-18" long to those holes. At the other end, fix a short piece chain with a bolt through the flatbar. Hook the chain to something solid like an axle housing or fixed drawbar. Slide the pump on the PTO shaft.
I know, I know. It sounds mickey-mouse but that is the way it is engineered and is factory suggested and approved.
I do have a picture but it won't do you any good. My pump is ridgidly mounted to a homemade fasthitch on a 650. It has an oversized top link bracket that has provisions for the pump.
