Re: Update on Farmal M with clutch problems
Posted by tennhillbilly on October 15, 2009 at 07:29:06 from (75.136.207.35):
In Reply to: Re: Update on Farmal M with clutch problems posted by Southern Ray on October 15, 2009 at 06:28:10:
No we have the belly pump removed When we bought this tractor it had a live pump on it and the belly pump was being used as a resevoir.It had the clutch problem when we bought it and we replaced the clutch disc, pressure plate,throwout bearing,pilot bearing and it still had the problem untill we shimed out the pressure plate.Now it is liveable if you wait several seconds before shifting into gear.
Thanks!!
