Re: 2444 w/ Loader Hydraulic capacity
Posted by bc on October 15, 2009 at 07:30:39 from (67.66.111.187):
In Reply to: 2444 w/ Loader Hydraulic capacity posted by fyr808 on October 14, 2009 at 17:30:01:
I assume you pulled the top plate off the rockshaft housing under the seat and cleaned that mess out. Assuming your 2444 has one. It will hold 2 or 3 gallons. It should refill by the pump if the plate is back on. Run it for a while and then check the level again.
