Re: Super A hydrolic leak
Posted by Hugh MacKay on October 15, 2009 at 08:19:37 from (209.226.247.74):
In Reply to: Super A hydrolic leak posted by JD in B.C. on October 15, 2009 at 07:55:13:
JD: There are a number of folks on here have repaired that leak. It leaks around the pump shaft then into timing gears and onto the crankcase. Shaft get worn, and it takes what they call a speedy sleeve. CNKS. Pete & R Pete are a couple I can think of. I've never had to do it, knock on wood.
