Re: Super A hydrolic leak
Posted by CNKS on October 15, 2009 at 09:02:52 from (216.144.104.128):
In Reply to: Super A hydrolic leak posted by JD in B.C. on October 15, 2009 at 07:55:13:
The front engine seal and the one on your pump are not related. You need to replace the pump seal, and the engine seal too. I suppose a higher oil level would cause a bigger leak, but if the oil is an external leak, it will continue leaking after the pump is fixed. Take the pump off and look at it, the repair is pretty much self-explanatory. If the seal is an oring, you will need to have the shaft hole enlarged to accept the speedi sleeve.
