Re: TA in 400
Posted by Janicholson on October 15, 2009 at 10:32:46 from (199.17.6.222):
In Reply to: TA in 400 posted by Nathon on October 15, 2009 at 10:10:29:
The TA clutch is similar to a regular (main) clutch. It is located in front of the TA and behind the main clutch. If it slips in direct, it is that clutch slipping. It is slipping for one of two reasons.
It is worn out and cannot be made new by anything but replacment.
It is not in adjustment, and is partially released in operation. Go through the Manual procedure for adjusting the TA and main clutch. Do it step by step and repair all worn pins and clevices if found in the linkages. If it still slips, it needs a new TA clutch, (change the ramp/rollers/sprague clutch at the same time. JimN
