Re: Dent in gas tank....
Posted by glennster on October 15, 2009 at 13:28:23 from (99.139.125.51):
In Reply to: Dent in gas tank.... posted by Dave H (MI) on October 15, 2009 at 12:23:11:
two ways we get dents like that out. tank must be clean and fume free. method one, stud welder and dent puller. gun spot welds studs to the dented area and slide hammer pulls the dent out.
second method. get some 1/2 inch or 5/8 cold rolled round stock. round one end up n a grinder and smooth with a sanding disc. then make some bends in the rod to make kind of a hook so you can go in thru the filler neck opening and pick the dent out from the inside. sometimes you will need to apply heat to help push the dent out. or take the tank to your nearby body shop and have them take it out for you.
