Re: Farmall Cub Relay Help
Posted by Janicholson on October 15, 2009 at 16:08:20 from (199.17.6.222):
In Reply to: Farmall Cub Relay Help posted by Tash329 on October 15, 2009 at 15:39:51:
If your cub has a 4 position light switch Low High Dim Bright. and it is not using one of the terminals of the "cutout relay". I would gut the relay box and put a power diode in the space inside of it. A 20 amp diode out of a junk alternator (stripped out of the diode pack) will work fine. The diode does exactly what the relay did, but will last forever, and look very stock/original. It must be attached so it is not grounded, and the conduction direction is from Gen to amp gauge, not the other way. (many do not have markings, so testing the flow to ground with a test light from the negative battery post (assumes Positive ground) through the diode will not light the light. This assures the correct connection allowing charging current to the battery, but no flow from battery to gen. Jimn
