Re: 300u rear axle leaking
Posted by Cub149 on October 15, 2009 at 18:39:19 from (98.17.213.96):
In Reply to: 300u rear axle leaking posted by JPSmith on October 14, 2009 at 19:48:46:
I did this last fall and it went very well. I took off the rim and tire, not filled and easy to handle. Then took off the wheel and pulled the hub off the axle splines. This is where I thought I would have trouble, but the splines still had lube on them and the hub pulled right off. Be sure to get the o-ring that keeps oil from leaking out through the splines.
