It unscrews counter clockwise. I have gottem them off by putting the pto in gear and then installing an old pto implement shaft on the pto and locking it so the pto can't turn. The pto is directly connected to the transmission counter shaft which is what drives the belly pump. Once the shaft is locked so it can't turn, you should be able to get it off with a bar in the slotted coupling.
Today's Featured Article - Tuning Up Your Tractor: Cooling and Fuel Systems, Hoses and Belts - by Curtis Von Fange. Our tractor is coming right along. The old oil and filter has been taken to the recycler and the air filter replacement has breathed new life into our motor. Let's take a closer look, now, at the cooling system since it has to work so hard in the summer heat. Cooling systems can be real cantankerous in their old age. Radiator cores clog up with rust, lime or other mineral deposits and the fins clog up with weed seeds and debris. The metal headers slowly corrode away from years of use and
... [Read Article]
Latest Ad:
[More Ads]
