Re: F14 fuel pump rebuild
Posted by tractorhank on October 15, 2009 at 19:21:51 from (24.124.104.36):
In Reply to: F14 fuel pump rebuild posted by jasonh76 on October 15, 2009 at 17:05:11:
I ran into the same problem with my F-14 since it had one of the original fuel pumps that had not had the diaphram replaced. I just ground the top of the pin holding the disc and then just got a small stainless steel screw and drill and tapped a hole for it and put the whole thing back together. Worked like a charm.
