Re: Farmall H Transmission seal for Hydraulic Drive shaft
Posted by Bill Bowen on October 16, 2009 at 06:11:43 from (99.130.146.89):
In Reply to: Farmall H Transmission seal for Hydraulic Drive shaft posted by Aaron H on October 15, 2009 at 17:28:51:
weld a bar to a old socket and use impact wrench.make sure it is a tight fit.first time i tried it i had to much slop.
Today's Featured Article - Tuning Up Your Tractor: Cooling and Fuel Systems, Hoses and Belts - by Curtis Von Fange. Our tractor is coming right along. The old oil and filter has been taken to the recycler and the air filter replacement has breathed new life into our motor. Let's take a closer look, now, at the cooling system since it has to work so hard in the summer heat. Cooling systems can be real cantankerous in their old age. Radiator cores clog up with rust, lime or other mineral deposits and the fins clog up with weed seeds and debris. The metal headers slowly corrode away from years of use and ... [Read Article]
