Re: difference between non-super and super
Posted by CNKS on October 16, 2009 at 14:28:48 from (216.144.104.128):
In Reply to: difference between non-super and super posted by JamesAlan on October 16, 2009 at 14:11:46:
There are several minor differences which will be mentioned by others. Being lazy, the easiest way to tell are the cast housings of the disk brakes on the SC as opposed to the stamped steel ones over the C's band brakes, and the curved brake and clutch pedals on the SC as opposed to the straight ones on the C. Others will mention the taller grill with the wide strip at the bottom, and the space between the gas tank and the hydraulic block, along with the C123 engine. Your question has been answered at least 2000 times in the archives, so for more info check there.
