Re: International 404 exhaust manifold
Posted by oldhousehugger25 on October 16, 2009 at 18:02:46 from (205.188.116.73):
In Reply to: International 404 exhaust manifold posted by Byron F. Stone on October 16, 2009 at 16:34:42:
Bryan,
From your description, not quite sure what exactly is the problem but if it isn't cracked or rusted through there is a good possibility you can take the manifolds off and take them to a machine shop and have them mill the mating surfaces flat again. Then find some good thick gaskets and use new bolts after you chase the old threads in the block. The muffler is usually held to the outlet of the exhaust manifold with some type of clamp. If it’s horizontal it probably has to have a second hanger somewhere also.
I would bet there are a few old engines of that type laying around at wrecking yards but you have to research your part numbers and be able to discuss what your needs are in an articulate manner.
Good luck
John
