Everybody wants to just pump new pumps on and think that is the problem . Before i start to spend a mans hard earned money i first run a flow rate on the pump and see what the pump is doing first . As your loader may have small dia. cylinders and your tractor may have to low of a pressure relief in it's system and it is popping off before you want to make the loader work . As you may have a 1750 relief and the loader needs 2200 2300 to get max lifting . So getting the system flow rated and pressure tested in my thinking is money well spent BEFORE you jump in with both feet and put the pump in as you may just need to change the relief valve and do a filter change .
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
