Re: Where can I get reasonably priced parts for this?
Posted by west alton river rat on October 16, 2009 at 19:18:03 from (65.123.130.203):
In Reply to: Where can I get reasonably priced parts for this? posted by Alan K on October 15, 2009 at 17:22:10:
ALAN you should be able to buy blades for $50 FOR THE SET.Things we need to know such as hole size most are 1 1/2",width 3 or 4",thickness 1/4,or 3/8" or thicker,offset in inches,cw or ccw . I can help you if you want we ship and do not charge retail. Good luck GENE
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
