Re: Dent in gas tank....
Posted by Brian Schmidt on October 16, 2009 at 19:44:13 from (69.66.233.155):
In Reply to: Re: Dent in gas tank.... posted by CNKS on October 16, 2009 at 13:35:03:
Thick bondo can crack and shrink if a single thick layer is put on all at once. It peals off due to the heat it creates when curing. This can create moisture and rust under the surface. Thus preventing a good adhesion.
Recommended procedure is to apply body filler over an epoxy primer. Then seal it in with a final coat of epoxy primer. If bondo is put on in thinner layers and allowed to cure in between, it is fine for many years.
CNKS, I know you are an expert at painting and body work and highly respect your opinion. But I have been doing body work for nearly 25 years too and it does work if done properly.
