Re: Where can I get reasonably priced parts for this?
Posted by couv on October 16, 2009 at 19:57:15 from (24.32.176.113):
In Reply to: Where can I get reasonably priced parts for this? posted by Alan K on October 15, 2009 at 17:22:10:
look for a local tractor shop or welding shop that stocks TISCO items. They sell numerous width, length, and offset style blades. You should be able to find a match. I did.
Also, remember to bring your old shoulder bolts with you. They need to be changed, and TISCO supplies them also. There are numerous styles of these, and this is NOT an area you want to skimp on -----
in 1973, I was shredding,and one blade came off and ripped through the rear steel curtain of our shredder. TO THIS DAY --- WE NEVER HAVE FOUND IT !. Thank GOD it went backwards, and not forward !
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
