Re: IH 656 Hydro problem
Posted by rusty acres, ND on October 17, 2009 at 11:30:16 from (64.31.251.187):
In Reply to: IH 656 Hydro problem posted by LakeStates on October 14, 2009 at 20:31:59:
I have a Hydro 70 that was doing the same thing. The cause was the fiberglass housing which the speed ratio lever goes through was loose and not holding the speed ratio lever to the right far enough. Repositioned the housing and tightened the bolts... problem solved! I'm not sure if the 656 Hydro uses the same system, but it sounds like the same symptom.
