Got it working...
Posted by Alan K on October 17, 2009 at 19:28:04 from (206.146.93.176):
third party image
Doesnt cut too bad even with dull blades. Does have some vibration in it but found out the two mounting bolts for the blade arm (underneath the gearbox) are loose. I had to invert the hanger bearing to get the pto lined up more straight as the two mounts were broke and welded. Now if I only had some dry weather and cornstalks....
