Posted by Fank on October 18, 2009 at 09:13:55 from (69.19.14.33):
What is the valve adjustment dimension for a D188 engine? Turns out I must have the wrong manual for a 5413 front end loader tractor (early 60s vintage) or the manual is wrong. My manual shows a different adjusting order when you are at TDC (actually, the same as the gas engine)so either they have the adjust order diagrams reversed for the gas and diesel engines in the manual, or this engine is different. I went ahead and adjusted the valves that were closed then rotated one turn and adjusted the rest, which agreed with the gas engine diagram.
My question is, they said .010 for intake and 0.12 for exhaust warm, is that correct? All of mine were in the range of .025 or worse. I adjusted them to .015 for now.
Anybody know the correct dimensions for the D188 engine?
Today's Featured Article - Oil Bath Air Filters - by Chris Pratt. Some of us grew up thinking that an air filter was a paper thing that allowed air to pass while trapping dirt particles of a particles of a certain size. What a surprise to open up your first old tractor's air filter case and find a can that appears to be filled with the scrap metal swept from around a machine shop metal lathe. To top that off, you have a cup with oil in it ("why would you want to lubricate your carburetor?"). On closer examination (and some reading in a AC D-14 service manual), I found out that this is a pretty ingenious method of cleaning the air in the tractor's intake tract.
... [Read Article]
Latest Ad:
[More Ads]
