Re: Worked on my 400 this week
Posted by Wardner on October 18, 2009 at 10:12:45 from (4.154.242.107):
In Reply to: Re: Worked on my 400 this week posted by Nebraska Kirk on October 18, 2009 at 06:41:46:
Glad you got the good deal on the IPTO gear. Way
to go.
This may sound weird but how much do you want
(shipping included) for your old gear? I will be
cutting off the hollow shaft sections and broaching a
keyway in just the gear. I am adding two PTO
shafts to the bottom of the center section.
I think the USPS will mail it for $7 if weighs
less than seven pounds and you use their box.
My email is open as always.
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
