Re: farmall belly pump knocking
Posted by Janicholson on October 19, 2009 at 07:18:17 from (199.17.6.222):
In Reply to: farmall belly pump knocking posted by redblood on October 19, 2009 at 06:04:44:
If it is working, I would leave it alone. Change the oil, or filter the existing oil if it is pretty new, through cheese cloth. It probably chipped a tooth from a piece of solid material getting between the gears. It will not get better, but I would use it unless it gets very noisy. Be on the prowl for a different pump in the meantime. JimN
