Often times the spring in pump breaks going through the gears, not good, but you will feel a definete difference on the lever if it broke. Don't over look loose bolts holding pump in and as the transmission counter shaft is what drives pump you could have a trans bearing or gear problem so if and when you do get time to drop pump, see if noise is gone with out pump in . As long as pump still works good and probem is for sure in pump I would take it apart and you may have to touch up the gears to eliminate the racket.
Today's Featured Article - Hydraulic Basics - Part 2 - by Curtis Von Fange. In the last entry to this series we gave a brief overview of hydraulic system theory, its basic components and how it works. Now lets take a look at some general maintenance tips that will keep our system operating to its fullest potential. The two biggest enemies to a hydraulic system are dirt and water. Dirt can score the insides of cylinders, spool valves and pumps. Wate
... [Read Article]
Latest Ad:
[More Ads]
