Re: Farmall M Carb Settings?
Posted by rustred on October 19, 2009 at 09:15:51 from (72.172.100.113):
In Reply to: Farmall M Carb Settings? posted by Faster346 on October 19, 2009 at 08:41:17:
that third top screw is for the idle throttle stop.set engine idle to approx.425 rpm with this screw. a good # is 3 turns out for the btm.main adjusting screw. middle idle adjusting screw is 1 turn out and your very close. i set them as this after o/h and dont really hardly need to readjust.if your out in field plowing or working hard then may need to open the main 1/2 turn.
