Re: Farmall M Carb Settings?
Posted by rustyfarmall on October 19, 2009 at 09:34:23 from (209.152.78.140):
In Reply to: Farmall M Carb Settings? posted by old on October 19, 2009 at 08:51:43:
Rich, factory initial setting on that bottom screw is 3 turns out and if the tractor does not run at that setting then something else is wrong. 5 turns out will take the needle clear out of the metering jet and then you will have an over-rich condition.
