Re: Firing order on farmall H
Posted by El Toro on October 19, 2009 at 17:12:05 from (74.103.74.58):
In Reply to: Firing order on farmall H posted by Jeremy T on October 19, 2009 at 09:31:11:
You can pull No1 sparkplug near the radiator & bring No1 piston to TDC on the compression stroke. Then remove the cap and see where the rotor is pointing. That's where your No1 plug wire should be installed on the cap and to No1 sparkplug. Then use Jim's sketch for the other three. Hal
