Posted by gbs on October 19, 2009 at 20:58:21 from (209.177.239.222):
In Reply to: 826 battery draining posted by Chochy on October 19, 2009 at 10:21:41:
check battery with volt meter to see if alternator is charging to the correct voltage 14.5 to 14.9 while running.if so two things could be your trouble,first disconnect hot cable on battery, slow charge battery with battery charger until fully charged,had a new one in a truck that after a day or so of not running it wouldn't start,carried it back to alternator shop where purchased tech. gave me another, to us told to come back after mine in the morning, after charging over night, putit back in the truck worked perfect don,t know why but it did. second check alt.to make sure it's not staying excited or on when engine is shut off,asuming you have a 10 si delco unplug 2 wire plug from alt. check white or one that hooks to #1 termnial for voltage, should dead with engine and ignition off if not it will slowly drain battery,for other style alt.disconnect regulator while not in use, see if that solves problem, if it does alt. is staying on.
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
