Re: farmall belly pump knocking
Posted by redblood on October 20, 2009 at 07:07:39 from (64.12.116.14):
In Reply to: farmall belly pump knocking posted by redblood on October 19, 2009 at 06:04:44:
Thank you for the insight.
She got 40 acres more to drill so after that I'll look but it sounds like she's worn out.
I will be looking for another pump.
Thanks again,
Joe
Today's Featured Article - Talk of the Town: How to Remove a Broken Bolt - by Staff. Another neat discussion from the Tractor Talk Discussion Forum. The discussion started out with the following post: "I have an aluminum steering gear housing with a bolt broken off in it. The bolt is about a 3/8" x 1 1/2" bolt. I've already drilled the center of the bolt out with about 7/64" drill bit the entire length of the bolt. Only one end of the bolt is visible. I tried to use an easy out but it wasn't budging and I didn't want t ... [Read Article]
Latest Ad: 2022 John Deere 5045E, 4wd, front end loader and 3rd function with grapple. 120 hrs, 55k new, must sell [More Ads]
