Re: 6 volt Farmall Starter
Posted by wayne in mn on October 20, 2009 at 08:25:30 from (66.228.242.147):
In Reply to: 6 volt Farmall Starter posted by S/C Bob on October 20, 2009 at 08:04:45:
You need to be sure the cables and ends are in top condition; Use 2 gauge or larger for best results with 6 volts.
Today's Featured Article - Talk of the Town: How to Remove a Broken Bolt - by Staff. Another neat discussion from the Tractor Talk Discussion Forum. The discussion started out with the following post: "I have an aluminum steering gear housing with a bolt broken off in it. The bolt is about a 3/8" x 1 1/2" bolt. I've already drilled the center of the bolt out with about 7/64" drill bit the entire length of the bolt. Only one end of the bolt is visible. I tried to use an easy out but it wasn't budging and I didn't want t ... [Read Article]
Latest Ad: 2022 John Deere 5045E, 4wd, front end loader and 3rd function with grapple. 120 hrs, 55k new, must sell [More Ads]
