756D
Posted by Icuby on October 20, 2009 at 10:45:27 from (71.7.10.127):
I installed a rebuilt short block{310}and new gears and relief spring in oil pump. I am running 75 lbs.oil press at 2300 rpm.at opreating temp.IT manual says 35-50 lbs. What can I do to decrease the pressure? My gaskets seem to be leaking some ,thinking this may be do to to much oil pressure. I realize that this type engine can be very dirty do to oil leaks but dont like to see them on a new rebuild. Thanks
